Hi ,
Hope i put that in the right section
ANyway , i burn on a dvd a standard non-compressed avi file.
My friend got a brand new G4 powerbook and when he put the dvd in , the MAC sees that something the size of 3.5 gig is on the disk but doesn't see any file.
My friend got media player and all the codecs (my ile is not compressed so the codec thing shouldn't be a problem anyway)
Any ideas on that
more specifics on "it sees something"
what is the file type?
what icon did the mac display
does he/she has Video Lan Client or Perhaps MPlayerOSX installed?
These apps will play just about any video file without the need for codex's to be installed
if it truely is a divx, and you are viewing it in quickitme you must first off install the Mac version of the divx codex and 2nd use the "doctor" to correct the audio do quicktime can play it back
this is somewhat of a hastle so thats why VLC or MplayerOSX are so nice.
hope this helps
Stream from friend to friend program easy to make?
By Homebrew77 in forum Video Streaming DownloadingReplies: 0Last Post: 30th May 2011, 06:27 -
HC Encoder -How to open AVI files
By MI6 in forum Video ConversionReplies: 6Last Post: 30th Nov 2010, 14:15 -
cannot open avi file
By ione in forum Capturing and VCRReplies: 8Last Post: 14th Sep 2008, 21:02 -
Need an American 'friend'
By Gordo_ in forum Off topicReplies: 9Last Post: 4th Jun 2007, 09:36 -
Can't open AVI clips
By sndfx69 in forum Newbie / General discussionsReplies: 5Last Post: 28th May 2007, 20:17
